Pyle National K2 Steam Turbine Generator
- FLtenwheeler
Hi
Does anyone make castings for the a 1.5/1.6 scale Pyle National K2 Steam Turbine Generator?
Tim
Tim
- Dick_Morris
Re: Pyle National K2 Steam Turbine Generator
FYI, the K2 and the later K240 are essentially the same. I've read that Pyle National sold parts to upgrade from one to the other.
I 3D printed a K-2 generator in 1.593 scale. This particular material is good up to 170 degrees F if I recall, and if need be I will mount on an insulating board. Thought about doing castings but this is good enough for me.
https://imgur.com/xg4L3Cl,glfXS2b
There is on ebay from time to time a seller from New Zealand (francesh2005) who is offering Pyle National K2 turbogenerator detailed brass castings in 1.5" scale. They are to make a dummy unit but the castings can be made into a working unit if one is very resourceful. There are no drawings or instructions for this however.
The seller claims that he has produced a working unit from the castings but as I say there are no drawings or instructions on how to do this.
- FLtenwheeler
This is the one I was looking for.Carrdo wrote:There is on ebay from time to time a seller from New Zealand (francesh2005) who is offering Pyle National K2 turbogenerator detailed brass castings in 1.5" scale. They are to make a dummy unit but the castings can be made into a working unit if one is very resourceful. There are no drawings or instructions for this however.
Tim
- Greg_Lewis
I see one pictured in the DNC System Technologies ad in Australian Model Engineering magazine. Check http://www.dncsystems.dynalias.com/minirail.Carrdo wrote:There is on ebay from time to time a seller from New Zealand (francesh2005) who is offering Pyle National K2 turbogenerator detailed brass castings in 1.5" scale. They are to make a dummy unit but the castings can be made into a working unit if one is very resourceful. There are no drawings or instructions for this however.
I just received a set of the 1.5" scale Pyle National dummy K-2 castings from the supplier in New Zealand and I am very happy with them.
They are very detailed hard bronze investment castings and come with come the sprues attached. Chris supplies a fact sheet on how to remove the sprues and cleanup the castings. As well, he includes a x-section listing parts of the K-2 turbogenerator itself.
I have attached a couple of photos of what I have done with the castings so far. One needs to have a fine jewellers type saw to remove some of the sprues. One has to think about how to hold the castings as we are dealing here with some very hard bronze and delicate detail which can be damaged with careless clamping.
Chris has an email: frances_chris@xtra.co.nz for further info or purchases.
I have no commercial connection with this other than being a happy purchaser.
P.S. to my last post.
You should see his 2" scale NZR Ka971 Northern on Youtube.
