1/2 id flue brushes?
- johnpenn74
Does anyone out there have a good source of 1/2 id flue brushes? The copper .45 caliber jags wear out too fast. I would like to find steel or similar.
JP
JP
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
Like I'm actually gonna build all this stuff
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
- makinsmoke
Re: 1/2 id flue brushes?
Hi John,
Those 45 cal brushes should be brass wire,
not copper.
Do you have copper or steel flues? Not sure you'd
want to use steel wire in copper flues.
Just my two cents.
Brian
not copper.
Just my two cents.
Brian
I use a black nylon tube brush and put it on a 1/8" brass rod. It is flexible and I can get all the flues from the smoke box. I spin it with a portable drill. It goes through a lot easier than the gun cleaning brushes and does a good job of getting the soot out. I have been using this method for 25 plus years with good results.
Wayne
Wayne
There is a company here on the West Coast called Brush Research.They make all different size brushes and flex hones from very small diameter to large cylinder brushes and hones. I believe they have a web site.
How many brushes would you like? I have both steel and bronze. 8-32 threaded shank. $5 for two.
PM me if interested.
Bob D.
Bob D.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
3/4" Hunslet 4-6-0
I use a 20/28 gauge shotgun brush. You can buy them in copper or in stainless steel. the stainless steel ones are made in using large loops of stainless wire, and do a good job and will last longer. You probably should search on the internet for them because most of the local places that I've been to don't stock them. I use a 20/28 gauge brush for my 1/2" flues, and a 12 gauge version for the 3/4" flues.
Don't have any concerns about using the stainless brushes in your copper tubes. You're going to brush the tubes probably 2x per running day, and run the locomotive probably 15 days per year? It would take an awful long time to wear through that copper doing that. Besides, those are pretty thin wires.
https://www.ebay.com/p/Hoppes-20-Gauge- ... 1400016406
any well stocked gun store will have a large number of shotgun cleanning brush's for you to pick from.
stay on the shine side of the rail
