A while back I happened to order two british injectors which I purchased from two different suppliers figuring I would find out which worked best. A ways back I emailed Vendor A the following picture; His response I quote is;
Just to be sure I got it straight after checking everything else I email vendor B the list above and he shoots back the following response;#1= Cold water in
#2= Steam in
#3= Out to boiler
So who is right? I am most inclined to think the delivery of steam and water need to go close together hence 3=steam in, 1=water in, and 2=to boiler which stinks as I will need to replumb after heeding the advice of vendor A. What do all of you think?You have 2 & 3 the wrong way round. 3 is steam in. 2 is steam out.
Anyone have photos of one of these successfully in use?
Thanks,
Adam
