Hi All
I was able to get to the Illinois Railway Museum and was able to take picture and get measurements of the Worthington feed water heater on Chicago Burlington & Quincy 4963. As you can see from the picture the patent plate is missing. I would like to know what version of patent plate was installed on the B3. "BOILER FEED PUMP & FEED WATER HEATER" or "LOCOMOTIVE FEED WATER HEATER and PUMP" I would also like to get pictures of the top of a Worthington Feed Water Pump
Tim
Worthington B3 Feed Water Pump
Re: Worthington B3 Feed Water Pump
Hi Tim . Check Robert Dustin catolag I think he offers plates for that pump.
www.chaski.com
Yes, Robert has 2 styles of Worthington plates. I need some guidance on which one to use.
Tim
Tim
- Greg_Lewis
For future reference, to get photos from odd angles, get a monopod with a ball head. It's a trick photojournalists use when they need a high or low angle, or around a corner, that can't be conveniently reached. Use the self timer to trigger the shutter. I have an old Nikon Coolpix with a swivel body that allows me to see the screen while the lens is twisted at a different angle. Some of the new SLRs do that, too. That plus the monopod helps with these kinds of situations.
Check the Facebook page for southern pacific 982 that is in Houston . look through the pictures there is a shot with the ID plate.
www.chaski.com
Thanks, that helps out a lot.
Tim
Tim
