Back gouge welding
Moderators: cbrew, Harold_V
jlakes85
Back gouge welding
Post by jlakes85 »
Hi all,
If I'm doing a fusion pass first on the backside and then wanted to grind down to this pass from the front side, would I be looking for a change in texture of metal to signify that I've reached the fusion weld area? Thanks again.
-Jlakes85
dbstoo
Re: Back gouge welding
Post by dbstoo »
Nope. A good weld should not appear any different. That's why an acid etch is used to show the penetration when testing welds. The etching brings out the grain.
Dan
