Illinois Central Mikado Pilot
Moderators: Harold_V, cbrew
SteamHeaton
Post by SteamHeaton » Sat Jul 29, 2017 9:53 pm
I have been thinking about this pilot for quite a few years. I finally got around to making the 2 dies requipped to make the pilot.
765nkp
Re: Illinois Central Mikado Pilot
Post by 765nkp » Sat Jul 29, 2017 11:38 pm
Any pictures?
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 7:55 am
Progress from yesterday.
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 7:56 am
This was a test picture. The center section is the final piece. The outside plates are test pieces.
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 8:30 am
These are the final 3 plates. I still have a little work to do. I still need to cut out the step in each outside plate. Then weld them to the frame.
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 8:32 am
This the pilot on the only surviving IC Mikado. This engine is in Paducah, Kentucky.
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 8:33 am
Side view.
PRR5406
Post by PRR5406 » Sun Jul 30, 2017 9:13 am
Very nice metal work! Those pilots were absolutely classics, and you've done a fine job of faithfully reproducing one in scale!
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 9:48 am
Thank you. This is my first time using a die . I first used a block of oak as the die. It would not hold up to repeated uses. It was so nice to see an idea come to life.
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 9:57 am
One of 2 dies I made to stamp these ribs. The center piece has a shorter rib.
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 10:00 am
This 20 ton press easily pressed the ribs.
SteamHeaton
Post by SteamHeaton » Sun Jul 30, 2017 10:01 am
Pilot frame.
