Page 2 of 3
Re: Oil burning boiler mods
Posted: Tue Aug 22, 2017 1:30 pm
by Marty_Knox
I use the water glass from LocoParts, I am working with Jeff to develop a bottom connection that projects into the water space. I prefer to drill and tap the backhead rather than use a half coupling.
Posted: Tue Aug 22, 2017 2:28 pm
by makinsmoke
Perfect!
Posted: Sat Sep 23, 2017 9:29 pm
by Vance Nickerson
Just give me a call I'm finishing up a coal to oil conversion on a Pacific right now and tested it yesterday awesome results with a Bagley burner.
Posted: Sun Sep 24, 2017 7:43 am
by makinsmoke
Hoping to see that Pacific running in about three weeks!
Posted: Sun Sep 24, 2017 9:54 am
by Vance Nickerson
I'm burning the candle at both ends trying to make it.
Posted: Thu Sep 28, 2017 9:48 pm
by Vance Nickerson
Makinsmoke. Brian, YouTube my name I put a video of the Pacific under full pressure. You can see the results with a Bagley.
Posted: Fri Sep 29, 2017 12:46 pm
by ChipsAhoy
Marty,
Currently saving up to have a boiler made for my loooong term 10 wheeler build, (I priced one from you last year). Why is it you recommend steel tubes vs K copper in an oil fired version? Seal welded one end?
Scotty
Posted: Fri Sep 29, 2017 1:53 pm
by Marty_Knox
The oil fire ramps up and down so fast copper tubes can pull away from the sheet and start leaking.
Seal welding the steel tubes at the firebox end transfers the heat into the sheet better and keeps the end of the tube from burning.
Posted: Fri Sep 29, 2017 2:41 pm
by ChipsAhoy
Marty_Knox wrote:The oil fire ramps up and down so fast copper tubes can pull away from the sheet and start leaking.
.... and roll the smokebox end?
Thks... good info to know!,
Scotty
Posted: Fri Sep 29, 2017 3:06 pm
by Marty_Knox
Yes, both ends are rolled. The firebox end is rolled, seal welded, then re-rolled. This keeps the seal on the water side.
Posted: Sat Sep 30, 2017 10:24 am
by NP317
Marty_Knox wrote:Yes, both ends are rolled. The firebox end is rolled, seal welded, then re-rolled. This keeps the seal on the water side.
That is prototype practice, for good reasons as noted by Marty.
Posted: Sun Nov 17, 2019 1:35 am
by ccoleman
What type of steel alloy and wall thickness would you recommend Marty?
