Fire watch, solid fuel run at Train Mountain?
rkcarguy
Re: Fire watch, solid fuel run at Train Mountain?
Post by rkcarguy » Wed Dec 06, 2017 11:36 am
What's involved to switch to propane, is it very complex, or just a matter of cleaning the firebox out and slipping a burner in there?
And adding a propane tank and hose obviously...
cbrew
Post by cbrew » Wed Dec 06, 2017 2:09 pm
rkcarguy wrote:What's involved to switch to propane, is it very complex, or just a matter of cleaning the firebox out and slipping a burner in there?
as a temp solution, this will work. but to get max efficiency. the front end needs to be changed. propane does not need the draft that coal and oil demand. if just needs enough draft for a clean burn. and more, its just cooling the fire box
