Page 3 of 3
Re: Fire watch, solid fuel run at Train Mountain?
Posted: Wed Dec 06, 2017 11:36 am
by rkcarguy
What's involved to switch to propane, is it very complex, or just a matter of cleaning the firebox out and slipping a burner in there?
And adding a propane tank and hose obviously...
Posted: Wed Dec 06, 2017 2:09 pm
by cbrew
rkcarguy wrote:What's involved to switch to propane, is it very complex, or just a matter of cleaning the firebox out and slipping a burner in there?
as a temp solution, this will work. but to get max efficiency. the front end needs to be changed. propane does not need the draft that coal and oil demand. if just needs enough draft for a clean burn. and more, its just cooling the fire box
