STARTER VALVE PROBLEM SOLVED
Moderators: Harold_V, cbrew
Trainman4602
Post by Trainman4602 » Tue Oct 17, 2017 12:03 pm
Some of my customers have been having problems with the starter valve. This is do to the use of a square section "O" ring. The incoming steam catches the edge and pulls it off.
I thought the this style seal would work and it did under a hydro test. Evidently under steam is a different story.
I originally used a regular round section "O" ring that worked over hundreds of cycles with out problems.
If you are having problems of the seal blowing off please PM me and I will send you the round section type.
Thanks Dave
PS I will be at a meet in Canton GA for a week so I will address this when I return.
