Cylinder Cocks....grime or seal
Moderators: Harold_V, cbrew
utahwestie
Post by utahwestie » Thu Oct 26, 2017 10:23 am
Hello all,
looking for some advice. I've taken the cylinder cocks off my Mogul for cleaning. I believe these are from Super Scale.
In the picture below with the beat up screwdriver as a pointer, my question is. Is this grime build up or is it a seal of some sort. I took them apart and had them soaking in simple green for a few minutes and the started to wipe with a paper towel to remove the crud. It looks like it might be a seal that has deteriorated but i'm holding off until I seek your advice.
Grime or damaged seal?
Thanks for all the help and advice.
~Anthony~
~Ex Pat Kiwi now living in Salt Lake City, Utah
Fred_V
Re: Cylinder Cocks....grime or seal
Post by Fred_V » Sat Oct 28, 2017 7:09 am
I think it is grime. under that should be a disk that the control steam pushes against to close the drain.
Fred V
Pensacola, Fl.
cbrew
Post by cbrew » Sat Oct 28, 2017 8:34 am
mine did not have any seals when i cleaned them after they loaded up from casting sand that was blown out the first time she was steamed, you are looking at "dirt",
[url=http://chris.brewfamily.info][color=red][u][b]Visit my website here.[/b][/u][/color][/url]
utahwestie
Post by utahwestie » Sat Oct 28, 2017 8:37 am
Thank you all.
I'll keep cleaning.....
~Anthony~
