Cylinder Cocks....grime or seal
Posted: Thu Oct 26, 2017 10:23 am
Hello all,
looking for some advice. I've taken the cylinder cocks off my Mogul for cleaning. I believe these are from Super Scale.
In the picture below with the beat up screwdriver as a pointer, my question is. Is this grime build up or is it a seal of some sort. I took them apart and had them soaking in simple green for a few minutes and the started to wipe with a paper towel to remove the crud. It looks like it might be a seal that has deteriorated but i'm holding off until I seek your advice.
Grime or damaged seal?
Thanks for all the help and advice.
