Machining Split Bearings
jlakes85
Post by jlakes85 » Thu Nov 09, 2017 7:28 am
Hi All,
In the last I've soft soldered the blanks together before doing the final boring and machining operations. Would loctite 609/638 be able to perform the same function, without the hassle of having the two halves float around while hot?
-jlakes85
Re: Machining Split Bearings
Post by John Hasler » Thu Nov 09, 2017 9:21 am
638 is only good to 300F. Higher melting point solder? But what do you mean by "floating around while hot"? Whlie machining?
jlakes85
Post by jlakes85 » Thu Nov 09, 2017 9:44 am
Hi John,
I was referring to the point where the rough bearing castings are sawn apart, cleaned up in the mill, then as they're soft soldered together, they have a tendency to float around during the liquidous phase. Keith Appleton did a video on YouTube showing how this can be an issue. I was wondering if it might be easier to use one of the green high strength loctites to achieve same
cbrew
Post by cbrew » Thu Nov 09, 2017 9:50 am
Morning
its clear we do not have the full story,
assuming these are axle boxes. why not use locating pins/screws to locate the two half's during machining and while they are in service?
or if surface area is limited. one can machine up a fixture that can secure the two half's until the boring procedure is complete.
Post by NP317 » Thu Nov 09, 2017 10:17 am
I do not see any reason why a LocTite adhesive could not be used as described.
Just make sure it is a low-temp mix, for easy separation post-machining.
Post by John Hasler » Thu Nov 09, 2017 10:41 am
jlakes85 wrote:Hi John,
I see. Why not use superglue (the thin kind)? It'll give you a thinner and more consistent glue line. 638 is a gap filler. You'll want to lightly sand the surfaces for any glue.
Post by Bill Shields » Sat Nov 11, 2017 12:02 pm
do it all the time with Loctite...
also put an air line at the chuck / collet to keep things cool...or flush coolant if you have it.
another way is to put a radial pin in each bearing and in the fixture. Drill the bearing through the diameter before you saw it in half (old car bearing trick).
Post by NP317 » Sat Nov 11, 2017 12:08 pm
Bill Shields wrote:[snip]
I can't picture what you are suggesting. More explanation, please? I'd like to understand.
