Page 3 of 3
Re: Mounting Water Glass
Posted: Wed Dec 27, 2017 11:44 am
by NP317
Yikes! Someone did not know what they were doing.
"Looks OK. Must be OK."
Wrong.
Posted: Thu Dec 28, 2017 6:45 am
by jlakes85
Vance,
Wow! Where/in what way did the boiler fail due to low water? The top of my glass is now slightly above the top of the barrel, but I have a tall dome so no worries about priming if I really overfill it.
Posted: Thu Dec 28, 2017 9:18 am
by Fender
jlakes85 wrote:Vance,
You’ll find from experience what water level causes priming. Even if the level is below the dome, the rapid boiling can cause water to carry over into the dry pipe.
If the boiler has rolled-in copper tubes, a low-water situation usually causes the top row of tubes to begin leaking.
Posted: Sat Feb 03, 2018 3:14 pm
by jlakes85
Hi all,
Here is a temporary piping arrangement with 5/16 copper tube. Am I asking for trouble with this?
Posted: Sat Feb 03, 2018 9:06 pm
by NP317
You usually want the upper connection to be at the highest point of the boiler barrel.
Posted: Sat Feb 03, 2018 9:38 pm
by Marty_Knox
jlakes85 wrote: Sat Feb 03, 2018 3:14 pm IMG_20180203_151004020.jpgHi all,
Yes you are. Look at the attachment in my second response in this thread.
Posted: Sun Feb 04, 2018 8:07 am
by jlakes85
Hi Marty
Sounds good. Believe me I know it's ugly and I'm guessing the length of top piping is causing issue. The first few go around with rigid piping were a flop. Just ordered some more stuff from pm research and mc master
