Belpaire Boiler for a PRR G-5
Moderators: cbrew, Harold_V
Re: Belpaire Boiler for a PRR G-5
Post by SteveM »
Nice work, Marty.
Your welding is neater than my caulking the bathtub!
Marty_Knox
Post by Marty_Knox »
Thank you Steve, but that is Glenn Grasley's welding. He has been working with me for the last five years, and is about the best welder I've known.
jlakes85
Post by jlakes85 »
Marty,
Looks great. A lot more hydraulic press oragami than the shay boiler. What type of Miller Tig machine is that in the background? Looks like a 3 phase machine.
Regards,
John
Marty_Knox
jlakes85 wrote:Marty,
Regards,
John
Hi John - Thank you!
It is a Miller Dialarc HF, a 300 amp machine for TIG and Stick. We do have 3 phase in the shop, but that is a single phase machine.
Marty_Knox
Here Glenn is welding the stays inside the firebox. The vacuum is set up to draw the fumes out.
Marty_Knox
The stand wouldn't go low enough to level the mud ring, so Glenn improvised. A length of pipe made a good support.
Marty_Knox
Here are some views of the inner firebox.
Marty_Knox
Here is the inner firebox after welding. The pipes keep it from distorting from the welds.
JohnHudak
Post by JohnHudak »
Wow...!
Marty_Knox
Here Glenn is lapping the dome base.
Marty_Knox
Here he is lapping the dome cap. We have a large lapping plate, a small lapping plate, and a hand lap. We use Timesaver non-imbedding lapping compound. The flatter the mating surfaces are, the easier it is to get them to seal.
765nkp
Post by 765nkp »
Marty, the boiler looks great. I have a question about the through stays, what size of pipe do you use for that? Sch 80?
Thanks Tim
