Re: Tender bladder
Posted: Mon Jan 22, 2018 5:24 pm
Since this subject is about tender tanks here goes.I'm building a Railroad Supply 2-6-0 and I have a fiberglass tender tank to use .I have 2 Locoparts tender water valves to install but here is the problem I'm trying to figure out.They are to be installed up through the steel floor,into the fiberglass tank.Anyone familiar with these one piece tanks knows there is limited space in the water legs,so how do you go about properly sealing around the water valves without possibly plugging the water intake holes on the valves.This shouldn't be so complicated,but it seems to be.My friend and I have discussed maybe just building a all steel tender,but I would really like to make do with what I have,if possible.I hope I have explained this right.
