Water pre-heat question.
cp4449
Post by cp4449 » Mon Feb 05, 2018 3:53 pm
Has anyone done either:
A: Placed about 2-4 coils of feed water pipe inside the front of the smoke box, to preheat the water? If done, does the copper pipe hold up?
or
B: Used a closed steam line into the tender to heat the water before being sent to the boiler? (I would assume i one sits on the tender, you rear might get warm)
Thanks for any replies
C.P. Mahony
Former 1" Foreman
Los Angeles Live Steamers
makinsmoke
Re: Water pre-heat question.
Post by makinsmoke » Mon Feb 05, 2018 4:07 pm
Do NOT heat your water in the tender.
One of the reasons injectors won't lift is if they get too hot. A leaking boiler check valve is the usual culprit.
A friend had a return line to the tender that somehow got hot. The water in the tender got hot and the injectors quit working.
Tested by running cold water from a hose onto one injector. Once we figured that out, a hand into the tender weather revealed the source of the problem.
makinsmoke
Post by makinsmoke » Mon Feb 05, 2018 4:08 pm
The Gene Allen design has a coil or two of copper line from the axle pump, around the inside of the smokebox to preheat the water before pumping into the boiler.
cp4449
Post by cp4449 » Mon Feb 05, 2018 4:59 pm
Then I will do the Gene Allen design. That seems safer, and easy to do.
C.P. Mahony
Former 1" Foreman
Pontiacguy1
Post by Pontiacguy1 » Mon Feb 05, 2018 5:22 pm
make sure your lines are out of the way, and also make sure they are easy to clean. they will get a lot of crap sticking to them and need to be cleaned pretty often. Also, you need to use copper on these or you won't be doing any good. I like to use stainless steel for my tubing inside of the smoke box, but a stainless steel feedwater heater would transfer so little heat as to be useless.
Post by Bill Shields » Mon Feb 05, 2018 5:34 pm
preheaters of this coil type, and one that I just removed from a loco that looked like a 'bed stead' are a mess to keep clean and take a real beating.
once you have one that works, make a spare and stick it in your tool box....
cp4449
Post by cp4449 » Mon Feb 05, 2018 5:48 pm
How about three large coils around the inside of the smoke box walls, right near the door?
C.P. Mahony
Former 1" Foreman
Post by Bill Shields » Mon Feb 05, 2018 9:45 pm
whatever you can fit and clean around is better than nothing.
how much better is to be determined.
Suggest you build it so that it can be removed easily...
