Re: Cast iron ate my drill
Posted: Wed Feb 07, 2018 12:20 pm
Just completed machine work on a 20 year old Winton Brown stack casting and base casting. The base casting machined real well with no problems. The stack casting looked to be of a different variety of cast iron and had some suspicious appearing surface imperfections as if the metal was a bit on the cold side when poured at the foundry.
I did some clean up grinding on the stack to make it ready for turning in the lathe. Once in the lathe, the base of the stack casting soon became problematic by eating HSS tooling. I converted to carbide insert tooling which also seemed to bounce and slide over the hard spot. Before each pass with the lathe tool, I made a pass with a small stone in the Dremel tool. Worse was the hard spot never did go away, it only seemed to change in shape as the cuts went deeper. Ended up with a slight low spot that will never be seen when the stack is fitted into the base.
Later I was cleaning up the top rim of the stack casting and ran into another hard spot. This time I just used a bigger stone in an air powered die grinder and soon made quick work of the problematic casting. Sometimes a bit of careful work with hand grinders can have our rock hard castings looking just fine without the damage to precision cutting tools.
