cylinder cock plumbing
Chris Hollands
Post by Chris Hollands » Sat Feb 10, 2018 12:38 pm
I need some ideas on plumbing the front cylinder cocks on the challenger , I thought I had some pictures of the setup on Tom Millers BB but just the rear cylinders.
This is a pretty tight area and with the movement of the front truck it really limits tubing arrangements.
Some one may have a photo of Toms or Brunos front cylinders showing what they did on there locos.
I did start out with an idea but it did not work out , so if any one has photos of similar large locos showing the cylinder cock plumbing it would help a lot.
makinsmoke
Re: cylinder cock plumbing
Post by makinsmoke » Sat Feb 10, 2018 1:24 pm
The first thing that comes to my mind looking at your arrangement is why not 45 degree els instead of the standard 90.
You can run both front and back towards the center of the cylinders.
Just a thought....
Chris Hollands
Post by Chris Hollands » Sat Feb 10, 2018 1:40 pm
That is not really the issue , its where to run the lines from the cylinder and onto the chassis .
I need a few ideas for that as a package if that make sense .
VO4454
Post by VO4454 » Sat Feb 10, 2018 5:25 pm
Hello Chris,
Here are some pics of the piping on my Northern that Ed Yungling and I assembled. I made unions to connect the piping to the cylinder cocks. 1/8 mpt to 1/8 copper tubing. The tee in the pics is a brass turning. All tubing connections were silver soldered. You can see in the photos that I brought the tubing up the side of the cylinders and to the rear. The steam line connection fitting was fabricated from a 1/8 tee compression fiting and a 90 degree 3/16 compression fitting silver soldered together.
Vic
Right side routing
For Duty and Humanity
VO4454
Post by VO4454 » Sat Feb 10, 2018 5:38 pm
More photos
Steam line connection
Chris Hollands
Post by Chris Hollands » Sat Feb 10, 2018 5:41 pm
Thanks Vic , that is what i'm looking for those type of photos .
Keep them coming .
Chris
VO4454
Post by VO4454 » Sat Feb 10, 2018 5:45 pm
I will keep sending I attached 5 pics in each post previewed it OK and posted it and only on came thru?
VO4454
Post by VO4454 » Sat Feb 10, 2018 5:47 pm
More
Left side routing
VO4454
Post by VO4454 » Sat Feb 10, 2018 5:51 pm
More
Right side routing
Right side routing
left side routing
VO4454
Post by VO4454 » Sat Feb 10, 2018 5:54 pm
More
Left side piping
Right side piping
Right side piping
VO4454
Post by VO4454 » Sat Feb 10, 2018 6:17 pm
Last 2, If you need more let me know.
Vic
Right side connection to steam feedtee
Right side piping
WJH
Post by WJH » Sat Feb 10, 2018 7:43 pm
So steam pressure opens up the cocks?
