Wheels to axles — which Loctite?
- Trainman4602
Re: Wheels to axles — which Loctite?
That is an insult to master machinist everywhere Sorry
- Atkinson_Railroad
The clash of the Hobbyist verses actual Industry practices.
Opinion and Facts cloud each other… and eventually… those looking on don’t really know what to think.
An axle on a toy train can have any tolerance until its death.
In industry, it’s not a chance thing. Mechanical fits have to be correct.
If the wheel falls off and it’s attributed to a bad fit, and “glue”… well… you’re gonna have to answer to your decision.
In a hobby environment, it doesn’t matter.
Do it your own way.
John D. Atkinson
Do it your own way.
John D. Atkinson
And in industry adhesives are widely and routinely used.
- Greg_Lewis
Hi folks. Say…. my original post was a question about which Loctite would be the best choice for wheels to axles. I’d like to thank all those who made helpful suggestions.
My original post was not about whether Loctite is or is not good or useful, or whether someone is or is not a machinist. Those topics have been debated on this forum before. As the originator of this thread, I ask that you please keep on topic. If you want to debate Loctite, machining skills, or other topics, please re-start one of those threads or start a new one.
If anyone wants to know about my experience with precision mechanical devices, shoot me a p.m. and I’ll fill you in.
If you have used Loctite to secure riding car wheels to axles, I’m interested in knowing what you used. Otherwise, please don’t hijack the thread. Thanks.
Greg,
I've used 609 for wheels. I also used it on my interference fit on my Coles 0-4-0, just for giggles. The cars they are on are still on the axles and run fine.
On another note, John Bailie taught me to get to within .001 and then use a mill file to get to a .0005 interference, and that works great. (He also taught me about the 609.)
Matt Mason
The first Russian Ural sidecar motorcycles imported into the USA in the late 1990s (I had a 1998) appeared to have used salt water as a bolt setter. They had no access to Loctites.
A subsequent visit as a consultant to that Factory in western Siberia bore out our first impression! I sent them a case of Loctite as a gift.
It was appreciated.
It was appreciated.
- Greg_Lewis
Thanks, Matt. I hope to have this car done for the Sac meet.
I have used 609 successfully for wheels on axles. The only thing I have to add, is that is desirable to have a shoulder on the axle, so that the wheels are in gauge when each wheel is resting against the shoulder. That way you’re not trying to set the gauge while it’s setting up. Also, it’s peferable to have the axle oriented vertically when putting them together. The axle and bore are then coated with adhesive and the wheel is spun onto the axle with the wheel resting against the shoulder. This will distribute the adhesive and allow the wheel to self-center between its bore and the axle. If the axle is horizontal when it is inserted into the bore, there is a possibility that it will not be centered in the bore, depending on the size of the gap and the type of adhesive used.
Dan Watson
Chattanooga, TN
Chattanooga, TN
- Trainman4602
BOY this Loctite post gets more hits the the steam posts get. If you want to glue your model together then buy a plastic model kit and go to town with the glue.
- Greg_Lewis
Thanks, Fender. Good reminder on the vertical setup. These axles have shoulders.
- Benjamin Maggi
The chart on the first page of this thread (which I ironically came across by searching Google before I found the current thread) might be of use:
http://www.chaski.org/homemachinist/vie ... hp?t=78921
RC35 wheels, counter shaft and crank shaft on a Clishay back in the late 70's. 609 lately (one of the listed replacements for RC35).
