Eccentric Engineer Announcement - Small Scale Injectors in stock!
AnthonyDuarte
Re: Eccentric Engineer Announcement - Small Scale Injectors in stock!
Post by AnthonyDuarte » Tue Jun 26, 2018 10:12 am
Thank you everyone for the reports!
The injector will work in any orientation. Although if installed horizontally it would be slightly more advantageous to install it with the overflow facing up like Asteamhead has done.
Marty_Knox
Post by Marty_Knox » Tue Jun 26, 2018 11:56 am
Why is that, Anthony?
AnthonyDuarte
Post by AnthonyDuarte » Tue Jun 26, 2018 7:51 pm
With the injector in that orientation, gravity helps to keep the overflow check seated.
