WRENCHES!!!!
Re: WRENCHES!!!!
I DOUBT that you will find the need for anything other than 64ths.
I have several steam unions that require 17/64 and 19/64 open ends.
what is more remarkable is that I have several sets of old ignition wrenches (as described) that include these sizes.
You can also find some metric wrenches that will fit the bill.
Try Horizon Hobbies / Hobby Lobby / Great Planes for sizes of little wrenches
- Dick_Morris
Re: WRENCHES!!!!
For nut drivers I found a Wiha brand 8 piece set #26591 gives a good range of imperial sizes. However, I had to supplement them with a 4.5 mm driver from the same manufacturer. AME apparently uses 4.5mm hex stock for their #4 bolts and nuts.
Re: WRENCHES!!!!
I've run into that and wondered what it was. #4 is a useful size too.Dick_Morris wrote: ↑Fri Apr 27, 2018 12:26 am For nut drivers I found a Wiha brand 8 piece set #26591 gives a good range of imperial sizes. However, I had to supplement them with a 4.5 mm driver from the same manufacturer. AME apparently uses 4.5mm hex stock for their #4 bolts and nuts.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Re: WRENCHES!!!!
Actually, AME says that the #4-40 hex heads are 11/64", which is 0.172". A 4.5mm is 0.177" so it's the closest you're likely to find. I'm going to have to get one of those as well, so thanks for the part number. I ordered a bunch of #4-40 hex bolts, and no nut driver set that I've found has an 11/64" one in it. They all go from 5/32 straight to 3/16". I have a really nice Proto 1/4" drive socket set, but the smallest in it is 3/16".
Re: WRENCHES!!!!
Long ago I acquired a small socket set designed specifically for the model hex bolts. AME should sell those.
I even acquired a second set to keep one set with my locomotive.
Works fine all the time.
- Dick_Morris
Re: WRENCHES!!!!
I just went out and measured the #4s at .171". There is a little slop with the 4.5mm, but I suspect I could break the bolt before rounding the head.
Re: WRENCHES!!!!
is there a socket head metric bolt that uses a 4.5mm Allen wrench? I have made nut drivers from socket head screws before.
Just googled and found this:
https://www.amazon.com/T4840XESD45-Prec ... B0052CDM92
they are a bit proud of it though.
And this one:
https://www.homedepot.com/p/Klein-Tools ... 21&cj=true
more reasonable price.
And this one:
Fred V
Pensacola, Fl.
Pensacola, Fl.
- Dick_Morris
Re: WRENCHES!!!!
On the CK (manufacture's) web site the one from Amazon is listed as 4.5mm and 11/64".
I did some searching for an allen screw with a 4.5mm drive and didn't find one. If they are out there they aren't a standard size.
Re: WRENCHES!!!!
Try any supplyer of computer building tools, as there are many small nuts and bolts used to mount motherboards and other parts to the frame of the housing.
stay on the shine side of the rail
