0-6-0 Linkage Geometry Anyone?
rkcarguy
Post by rkcarguy » Fri May 04, 2018 2:52 pm
I'm curious if anyone has drawings for a USRA 0-6-0 as far as all the linkage, cylinder bore and stroke, and reversing linkage that I could draw in CAD and upscale to 2" scale?
I'm just looking for dimensions all relative to each other.
James Powell
Re: 0-6-0 Linkage Geometry Anyone?
Post by James Powell » Fri May 04, 2018 3:03 pm
You could, but I would suggest taking the #'s from upscaling valve gear, and put it into Docksteader's valve gear program, and see what the valve gear looks like. The other choice would be to take the full sized and scale it down ?
Berkman
Post by Berkman » Fri May 04, 2018 3:11 pm
Roger Goldman makes a 1.5 scale USRA 0-6-0. I'd give him a call, I bet he'd sell you a drawing set.
http://modelsteamengines.tripod.com/id13.html
rkcarguy
Post by rkcarguy » Fri May 04, 2018 3:33 pm
I emailed RG and I'll see what he says, thanks for the link. I really only need the full geometry, I can draw all the parts I need around that. I've already drawn the locomotive itself based off of the original basic blueprints, but it has no linkage or anything and the cylinders are just roughed in so they look about right.
rkcarguy
Post by rkcarguy » Fri May 04, 2018 3:47 pm
In fact, I will probably be even editing the geometry some. The L-9 Model here locally has slide valves and the front axle is moved further forward so the spacing isn't an even 5'-6" like the regular USRA 0-6-0's.
Berkman
Post by Berkman » Fri May 04, 2018 4:13 pm
What gauge are you building for 2inch scale?
rkcarguy
Post by rkcarguy » Fri May 04, 2018 5:33 pm
I am already building a "diesel" S-12 Baldwin switcher, see my working railroad post in grand scales if interested.
The funny part is, I'm going to have to dole out about $1000 for hydraulics to get it running. Being I work at a fab and machine shop, I can make my own parts and utilize scraps and remnants for almost all of a steamer. I'm in no hurry, but I might as well draw it up, and get it broken down into parts so as the opportunity comes I can get them made.
Because I wanted to have a nice wide gage for hauling trash and firewood on my property(no tip-overs), yet still be able to transport my loco's and rolling stock in the back of my pickup, I am doing 2" scale on 12" gage groovy-track type track, so no it's not to scale, as in 2" it should be about 9-7/16" gage.
Fred_V
Post by Fred_V » Sat May 05, 2018 6:45 am
Some guys are already building in 9" gauge, I think. You should use that gauge also.
Fred V
Pensacola, Fl.
rkcarguy
Post by rkcarguy » Mon May 07, 2018 12:20 pm
I don't have any tracks nearby, the only one is actually Glenn's in progress build which is also 12". That's my reason for going 12".
I haven't heard back from RG about their willingness to sell me a drawing set, so still at a standstill.
