Baking Tanks
Re: Baking Tanks
I used 2-56 stainless hex head bolts and washers for the tank tops, it's not scale, but, I like the looks of them. All of the fasteners on the sides are flat head. I added baffles for the insides as well. The baffles also help to keep the sides straight when the tank tops are removed. Yes, the RTV must be used on the screws as well, so, just a little squeezes out of the threaded hole in the brass angle. If your screws are countersunk well, there is no filing to be done. They should be pretty well flush with the outside of the tank plate.
David
David
Re: Baking Tanks
David,
That's about what I had in mind. It wouldn't take very many to keep the tops down.
Yes Keith, that's it.The Tich? - Keith
GWRdriver
Nashville TN
Nashville TN
Re: Baking Tanks
I soft soldered the saddle tank on my Hunslet. I riveted it together and used the acid flux and propane torch. Worked fine but I did have some leaks.I filled those with wickable Loctite.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Re: Baking Tanks
Hi Fred,
Nice work . . . I've never used Clecos. Not because I might not have had a need from time to time . . but because I've never owned any and have no experience with them. I could see where they could be as useful on a screwed-together job as a riveted one.
GWRdriver
Nashville TN
Nashville TN
Re: Baking Tanks
Glad to see that you are back to working on the Tich project! So, it will be ready to run about... September?? It really is looking great, can't wait to see it at the track. A shame to have to cover up such beautiful work with paint.
Re: Baking Tanks
A couple of answers . . . .
I initially posed myself several questions on Tank Baking and several are still unanswered, but two questions have been answered . . . a quickie test assembly was "baked" last night and came out very well so . .
FWIW, a conventional residential electric oven with a "bake" temperature setting of 500°F will definitely do soft solder assemblies.
Secondly, solder paste worked very well and would be the way to go, at least for the first round.
What did not come out as I expected on the test I put down to solder starvation . . . caused by over-thinning my old-stock 50/50 solder paste to soften it up. This actually bodes well for any smaller lighter gauge work I might do, but for what I have, fresh solder paste with maybe a splash of silver content should solve the problem. There are a few places where I'll want a nice fillet.
More, when there's more to report.
GWRdriver
Nashville TN
Nashville TN
Re: Baking Tanks
Can you put a pizza in at the same time?
Keith
Keith
