Tender valve
cp4449
Tender valve
Post by cp4449 » Thu Jun 28, 2018 3:37 pm
Who makes a good tender valve for feeding a injector line? Also, can I use a globe valve for the steam, or should it be a different style?
Thanks in advance.
C.P. Mahony
Former 1" Foreman
Los Angeles Live Steamers
FLSTEAM
Re: Tender valve
Post by FLSTEAM » Thu Jun 28, 2018 3:50 pm
For the tank valve I use 90 deg. ball valves with an extender shaft thru the tank top. For injector starting valve I use globe valves with the treads machined off and installed backwards i.e. the steam pressure holds the valve closed.
John B.
http://www.ngshay.com/
Shay drawings and castings
