Page 2 of 2
Re: 1" U in 1/4" copper tube
Posted: Wed Jul 11, 2018 2:10 pm
by gwrdriver
LivingLegend wrote:
Wed Jul 11, 2018 6:02 am
Keeps the ice from cracking.
My guess would be that the detergent doesn't freeze and provides a lubricant to allow slip movement between the ice and the tube as the bend is made.
I'll be that somewhere in the Blogoshpere there'is a YouTube on "How Horns are Made."
Posted: Wed Jul 11, 2018 3:23 pm
by Harold_V
Thanks. Interesting subject.
I once was successful in a bid for making several fuel lines from ½" aluminum tubing (defense contract).
A fixture was built that allowed the bends to be created without filling the tubing. I also built several formed tubes for the Bell helicopter helmet gunsight, which required two bends (offsets) that didn't distort the tubing, so this subject has been of interest to me.
Posted: Wed Jul 11, 2018 4:11 pm
by LivingLegend
DianneB wrote:
Wed Jul 11, 2018 9:25 am
....They also freeze the ice to around -60 or -70 degree range.....
I don't have dry ice in stock either and don't know how else you could get -60 or -70!!
Table salt is more finely grained than most sand.... Try sealing one end of the tube then fill it FULL of table salt instead of sand. Pack the salt tightly and then seal the other end of the tube. You'll want as little internal void (like none) in the tube as possible once it's sealed.
LL
Posted: Wed Jul 11, 2018 4:38 pm
by LivingLegend
Fender wrote:
Wed Jul 11, 2018 10:43 am
Depending on the degree of bending, one might need to anneal the tube, fill with solution, freeze, bend, rinse, repeat....😀
Nope. Regardless of what they use as a filler in the tubing of the instrument.... Cerrobend, pitch, or ice, they do the bend in one move.... Even complex compound curves.
LL
Posted: Wed Jul 11, 2018 8:05 pm
by John Hasler
Harold_V wrote:
Wed Jul 11, 2018 1:46 am
LivingLegend wrote:
Tue Jul 10, 2018 8:07 pm
They pour the soapy water into the tubing, freeze the tube, and then bend the tube around a form to the radius/curve/shape desired.
Any idea what function is performed by the addition of soap?
I think that the soap will cause the solution to gell rather than crystallizing as pure water would.
Posted: Thu Jul 12, 2018 7:44 am
by gwrdriver
Here you go . . . https://www.google.com/search?q=making+ ... #kpvalbx=1
The pertinent part begins at 3:18.
Posted: Thu Jul 12, 2018 8:45 am
by Fred_V
I've seen a video of trumpet making using pitch too.
Posted: Thu Jul 12, 2018 9:18 am
by SteveM
Popcorn salt is even finer grain.
Posted: Thu Jul 12, 2018 11:10 am
by Builder01
Pitch is so they get the notes correct!
David
Posted: Thu Jul 12, 2018 11:12 am
by BAdams
:wink: That's a "sharp" comment that could fall "flat". :D
Posted: Thu Jul 12, 2018 4:00 pm
by Harold_V
Thanks for that. It's something I'd never seen, and answered a lot of questions.
