The boiler jacket for the K-4
ebtfan
Post by ebtfan » Thu Jul 26, 2018 7:23 pm
For the past few months I have been bending, pounding, grinding, and fitting the sub jacket for my K-4. The sub jacket is 13 gage steel(approximately 3/32 thick). On top of this jacket will be placed a 22 gage steel detailed jacket made up of pieces as on the prototype. Those jacket pieces will be fastened to the sub jacket with 1-72 screws. The 13 gage sub jacket also allows direct mount of hand rails and accessories.
Berkman
Re: The boiler jacket for the K-4
Post by Berkman » Thu Jul 26, 2018 7:29 pm
has anyone added lead sheet under the jacket for added weight ?
daves1459
Post by daves1459 » Thu Jul 26, 2018 11:11 pm
I have. I got the lead sheet from McMaster-Carr. They have several thicknesses available. First I insulated the boiler with 3/32" thick adhesive back woven ceramic insulation, also from McMaster-Carr. The insulation comes in strip and sheet and is easy to work with. It molds nicely into corners and around radii. Then I cut and formed 3/32" thick lead sheet around boiler holding the joints closed with masking tape. The boiler had a conical section ahead of the fire box that was mocked up with the lagging and provided space for multiple layers of lead. Lastly The laging was fitted. I expected condesate to drip down the steam dome from the safeties. Since lead is corrosion active in water I painted the lead in that area with a heavy coat of epoxy paint.
Dave
Berkman
Post by Berkman » Fri Jul 27, 2018 7:53 am
Wonder how much weight that added?
david griner
Post by david griner » Fri Jul 27, 2018 1:30 pm
Outstanding work, Sir !!!
Fender
Post by Fender » Fri Jul 27, 2018 2:22 pm
Dave, is this an all-new jacket & sub-jacket, or are you re-using the original materials?
Dan Watson
ebtfan
Post by ebtfan » Fri Jul 27, 2018 4:59 pm
Dan. The k-4 in the photos is being built by Dan H. In Lancaster, PA. I am using the same construction techniques that Dave S. used on his 1361.
Glenn Brooks
Post by Glenn Brooks » Fri Jul 27, 2018 10:24 pm
Ebtfan,
Any chance you could post some closeup photos of how the sub jacket is made and fastened to to the frame or boiler. I will be wanting to do the same thing when I refurbish my old 12” ga wagon top boiler on my 4-4-0 this coming winter.
Thanks
Glenn B.
Fender
Post by Fender » Sat Jul 28, 2018 3:54 am
Oops, sorry.
Dan Watson
Mike McCotter
Post by Mike McCotter » Sat Jul 28, 2018 6:15 pm
Dan,
Thanks for posting the progress on your K-4. You are doing a beautiful job. Keep up the good work!!!!!
Mike McCotter
ebtfan
Post by ebtfan » Sun Jul 29, 2018 8:40 pm
Dave G. and Mike M. - thanks for the positive comments. This part of the project seemed overwhelming to me at times as I struggled at first to make several of the belpaire firebox jacket pieces from copper using formers. I ended up going with a predominantly steel jacket. If I had to make a living as a copper smith I would be in trouble.
Glenn B. - am sorry but I do not have any photos of the metal forming process. I did use some you tube videos describing procedures used by HVAC technicians to make different duct parts. I used those techniques to make templates for the sub jacket pieces. These pieces were fastened to the rings shown in the first photo. I used a combination of screws and weld to attach the plates to the rings.
daves1459
Post by daves1459 » Sun Jul 29, 2018 10:01 pm
It is a rather small boiler so the total added weight was not a lot. The weight as I recall was around 12 pounds. I also put a lead plug in the sand dome that weighed 7 pounds. The advertised weight of the loco was 250 pounds which is probably optimistic. I also put weight in the cab. One good thing about adding weight to the boiler shell and sand dome is the distribution of weight on the lead truck and drivers remains the same.
Dave
