Un Lucky 7 Stack
Moderators: cbrew, Harold_V
Fender
Re: Un Lucky 7 Stack
Post by Fender »
🍺 A toast to the machinist!
Dan Watson
Chattanooga, TN
steamingdon
Post by steamingdon »
Thanks! Keep the toast, I`ll have a beer or two. :D :D :D :D :D :D
steamer
rkcarguy
Post by rkcarguy »
Beautiful work!
How was the flange made and attached? Welded on and turned smooth?
If one piece with the stack, you must have had a milling setup for your lathe?
steamingdon
The flange is one piece with stack as explained earlier . It was generated on a old cross slide rotary. I do have other capabilities of generating this flange area, but, I decided to do it the old school way. I helped build the old school as well. :D :D :D :D :D :D Shop math always helps in these situations.
steamer
steamingdon
Oh! it was milled on a Bridgeport milling machine 1982. You would have one heck of a time trying to mill this in a manual lathe. Could be done on a CNC lathe with live tooling for sure. I just don`t have that kind of money laying around @ this time, or the floor space. I have just over 500 sq. ft. and we are just about full up. Made up form tool with Dremel and grinding wheel, works fine. Some times I think we over think simple projects. Is anyone else building this particular engine in 3 1/2" gauge ? :) :) :)
steamer
rkcarguy
Post by rkcarguy »
Ah ok I gotcha, I missed the cross-slide rotary part on the mill. Old school way, nice work.
steamingdon
I will post entire assembly when my photographer elm 53 shows up again. :D
steamer
steamingdon
maybe we will have a video ?
steamer
elm53
Post by elm53 »
Here's a vpiple more stack pics.
Down the stack!
Down the stack!
Petticoat ,stack and smokebox.
elm53
Post by elm53 »
Should have been a couple. Anyway ,..hers a few more Lucky 7 shots.
Valve crosshead
Valve crosshead
Valve crosshead from top
Vch from side.
Vch from side.
Cylinder crosshead..upside down..
elm53
Post by elm53 »
Crosshead pic was upside down in the file view ..its right side up here.
