14 ga. Steel Material cutting
jlakes85
Post by jlakes85 » Mon Aug 27, 2018 8:56 am
Hi All,
Need to get some 14 ga steel cut for tender material, though I don't have access to a shear that can handle that thickness of material. Would a jig saw be a decent work around, or should I go the torch route?
jlakes85
BClemens
Re: 14 ga. Steel Material cutting
Post by BClemens » Mon Aug 27, 2018 9:06 am
metal shear.pdf
(159.62 KiB) Downloaded 69 times
jlakes85
Post by jlakes85 » Mon Aug 27, 2018 9:38 am
Hi Bill,
Excellent suggestion..problem solved. Thanks again.
Regards,
jlakes85
Post by NP317 » Mon Aug 27, 2018 9:42 am
I used a jig saw with fine metal blades to cut the heavier steel sheet for runnings boards and such.
That process left edges requiring simple clean up on with a vertical belt sander, files, plus deburring.
I would have cut the cab parts that way too, but my son's employer learned to use their new laser cutter by practicing on my cab parts.
Successfully. I'm drilling rivet holes now.
BClemens
Post by BClemens » Mon Aug 27, 2018 9:46 am
jlakes85,
These shears work pretty well. I tried to resist buying a HF tool but needed a shear in a pinch so bought one. The next better one is a few hundred dollars too... We'll see I guess.... I'm cutting 20Ga 304 SS and figured I would be driving back to HF for a return but so far so good.
But a plasma cutter is the way to go!
BC
shild
Post by shild » Mon Aug 27, 2018 12:17 pm
When possible for smaller pieces, I'll run them in my mill/drill with smallest endmill I have. Once I bore a hole through I drop the head low as I can so it wears a part of the endmill that rarely gets used. So more even wear on my endmills.
Fender
Post by Fender » Mon Aug 27, 2018 12:41 pm
With practice you can make straight cuts very accurately with a cutting disk in an angle grinder. A trick to use with a bandsaw is to back up the metal with scrap plywood (put the plywood underneath). This help to keep the saw teeth from catching/snagging on the sheet metal.
Dan Watson
DavidF
Post by DavidF » Mon Aug 27, 2018 1:20 pm
Im for a cut wheel as well. just clamp a length of angle iron to what your cutting for a guide and let the side of the wheel ever so lightly run on it to keep you straight.. Those electric shears have made me a bit angry at times....
BClemens
Post by BClemens » Mon Aug 27, 2018 3:27 pm
The shears also waste a piece (curl) of metal the width of the blade for the entire cut. I didn't measure its width but it seems like about a quarter inch wide. I hate to throw things away much less waste them. The shears are also not easy to run along a guide for a straight cut.
----bad suggestion. Maybe a local sheet metal shop will do your shearing for you - it doesn't take long - Bam!
BC
Fender
Post by Fender » Mon Aug 27, 2018 8:06 pm
Nifty idea!
Dan Watson
Ken Schroeder
Post by Ken Schroeder » Mon Aug 27, 2018 11:52 pm
If you have a table saw get a metal cutting blade and it will work great. I have cut a lot of steel sheet on my table saw up to 3/16" thick. Just wear some safety goggles, safety shield and a long sleeve shirt. If you are like me with thin skin and thin blood you will look like you were in a war zone if you don't cover up. The nice thing is you can cut a very straight line with the table saw and fence.
Post by Harold_V » Tue Aug 28, 2018 1:46 am
You've received some excellent responses, but one thing has been overlooked. Torch cutting.
A torch is a magical and wondrous tool, but using it on thin material tends to create problems that are difficult to overcome. Thin material doesn't torch cut well unless you have the proper tip, and the resulting warping tends to render the parts cut less than useable. For thin material, I'd avoid torch work unless you had no other options.
