Valve for Vacuum Brake
doublereefed
Post by doublereefed » Sun Sep 09, 2018 4:14 pm
Seeking methods for plumbing the steam ejector to a valve. I'd like to use a 1/4 turn ball valve under the cab floor, then run a control rod up through cab floor and machine up a stand/handle. I can't find a good valve to use though. The smallest I have found are still quite big, and very stiff. Any advice appreciated.
southwestern737
Re: Valve for Vacuum Brake
Post by southwestern737 » Sun Sep 09, 2018 4:43 pm
The small ball valves from American Model Egineering, work very well for what you are trying to do. Just leave the handle on them and build an extension with a yoke on the end that grabs the handle.
Brent
Trainman4602
Post by Trainman4602 » Sun Sep 09, 2018 4:56 pm
Just as a second consider using my injector starter valve. I have seen this used for this application.
You can fit it up with a rod extension to the back of the cab. You get instant results with the ball valve you would have to make stops.
file (2).jpg (20.44 KiB) Viewed 896 times
