Hi All,
Can anyone advise of these are of the lifting variety? These are sized to go with 5/16 OD tubing and are rated at 6 pints/minute. Thanks
-jlakes85
Blackgates Engineering Injectors (No.7)
Re: Blackgates Engineering Injectors (No.7)
I have a No.4 injector from Blackgates. I do not think it is a "lifting" type. It needs a pretty good flow of cool water to it before opening the steam valve, and then it will pick up and start doing it's job.
David
David
I could never get my Blackgates number 4 injector to lift reliably....it would always gurgle and spit...I don't think blackgates are designed to lift??....I have since mounted mine down low, and it needs a good flow of cool water to work half way decent
