Pump
Re: Pump
Too mamy fiddly little parts inside. I have seem maybe 5 of them and none ran more tham a few monrhs.
Re: Pump
Very complex valving inside.
They typically have a vertical trigger rod inside the main piston shaft, that operates a slide valve for the horizontal shuttle valve, that operates the steam pistons.
All various forms of "control amplifier.", with many options to not work as intended, in miniature.
Re: Pump
Hmm....I didn't know they were so finicky....I've built several of the little engines single cylinder and twin cylinder pumps over the years, there pretty reliable, and work fairly well....guess I'll stick with one's of those, since you probably can't get the moes pumps anyway.....
Re: Pump
The Soler and / or Keim pumps, based on Bill van Brocklin's duplex (twin cylinder) design are very reliable.
If you want plans to build your own from these designs, they are readily available.
Re: Pump
from what I have seen they may well be...but I have never had the guts to take one apart
Re: Pump
Just to clarify a couple points, water pumps are never set up as compound. Water is an incompressible fluid and cannot be compressed a second time like an air compressor.
My two cylinder water pump is not based upon the Van Brocklin design. My pump contains the valve mechanism internally. The Van Brocklin and Solar pumps have external linkages that drive the valves. I'm not saying there is anything wrong with that design.
Both Van Brocklin and Solar work well when maintained.
Thanks,
Brian Keim
Keim Steam Pump
Extreme Steam
Thanks,
Brian Keim
Keim Steam Pump
Extreme Steam
Brian Keim
Re: Pump
Giggle....incompressible water???? must be an old-fashioned idea....
I have only seen the Moes' pumps connected for air service
Re: Pump
Are you out-of-date Bill? ROFL!Bill Shields wrote: ↑Wed Nov 07, 2018 10:33 am Giggle....incompressible water???? must be an old-fashioned idea....
