Engine stand
Re: Engine stand
Harbor freight products are awesome! Is that the same red the Central Machinery mill/drill, lathe, bandsaw, drill press and other products typically are? I'm trying to find a matching spray can because it's wearing off my machines.
Re: Engine stand
I put 2 tracks on my Harbor Freight stand for the American, tender & propane car (build is 98% complete)...this works great, wish I could use one of these for the Hudson but it is too heavy. I also put new casters on and extended them out a bit to keep the thing balanced. At $299 (with coupon) plus casters this can't be beat.
Re: Engine stand
the hudson engine only is too heavy ?
Re: Engine stand
It’s close to the 1000 pound limit the stand has and is a foot longer with the overhang...the wheel base works. Maybe I should reweigh and assess the length (the end of the stand stocks out a bit when the stand is lower (eg if I sit on the end of the stand with it all the way down when Emoty lifts the other side. You have me rethinking this as that would be great
- Dick_Morris
Re: Engine stand
Two HF stands end to end? The pumps would have to be ganged together so they would raise at the same rate, but it might work.the hudson engine only is too heavy ?
