Whistles
hoppercar
Whistles
Post by hoppercar » Tue Dec 04, 2018 12:15 pm
Does anyone out there build a good sounding whistle for 1 1/2 locomotive?....I've tried making several my self over the years, never really had a lot of luck....they were always gurggly sounding. watching YouTube videos I hear some pretty nice ones, ...don't care for the european, style, screechy...Thomas the tank engine PEEP PEEP peanut whistles.....
BClemens
Re: Whistles
Post by BClemens » Tue Dec 04, 2018 12:34 pm
There is an excellent article in Live Steam Magazine on the construction and tuning of steam whistles. I built a four chime one from the article and it sounds pretty nice. It is made using 1 1/2" brass tubing - it's about 10 - 11 inches long....
There is one on the Green Goddess that does that gurgle.... I haven't had time to see what might be wrong with it.
BC
ccvstmr
Re: Whistles
Post by ccvstmr » Tue Dec 04, 2018 6:13 pm
Which way are your whistles oriented? ...upright...or horizontal?
Wouldn't expect any gurgling from an upright whistle. Horizontal whistle...that's another matter. I put a 1/8" thick spacer bar under the rear whistle support. Wanted to make sure any condensate in the whistle chambers had a way to drain/run out. In addition...with a 4-note whistle...make sure the chamber dividers are at the 12, 3, 6 and 9 o-clock positions so condensate in ANY chamber can drain out. This helped my whistle some. Hope that helps. Carl B.
Wayne Davis
Re: Whistles
Post by Wayne Davis » Tue Dec 04, 2018 10:24 pm
November/December 1992 of Live Steam has an article called Whistle Clinic. This has symptoms then tells why it happens. I have used this article to help improve the sound of a whistle.
Wayne
BClemens
Re: Whistles
Post by BClemens » Wed Dec 05, 2018 5:26 am
Carl,
The whistle on the GG is under the firemans side cab - it trys to resemble an air tank. I'll try giving it a slight slant and see what happens next time we're steamed up.
Thanks, BC
BClemens
Re: Whistles
Post by BClemens » Wed Dec 05, 2018 5:29 am
Would it be OK to copy and post that article from LS? I ask because because of the magazine being out of print for a while.
BC
Dan_M
Re: Whistles
Post by Dan_M » Wed Dec 05, 2018 9:08 am
Try these guys out. They make excellent whistles.
http://rizzolilocomotiveworks.com/
Greg_Lewis
Re: Whistles
Post by Greg_Lewis » Wed Dec 05, 2018 10:46 am
BC
No, the copyright is still in effect.
Greg_Lewis
Re: Whistles
Post by Greg_Lewis » Wed Dec 05, 2018 10:49 am
Hoppercar:
There have been several threads here on whistles. A search will bring them up. I believe that others have mentioned the Mintz whistle as a good one.
dnevil
Re: Whistles
Post by dnevil » Wed Dec 05, 2018 11:19 am
More info on scale whistles can be found here:
http://ibls.org/mediawiki/index.php?title=Steam_whistle
Daris
Daris Nevil
IBLS Secretary
North American Region
http://www.ibls.org
Re: Whistles
Post by Harold_V » Wed Dec 05, 2018 4:48 pm
BC
Considering copyright, it likely wouldn't be acceptable. However, there are exceptions to the "rule". Perhaps one of the attorney's who frequent this board could offer a professional opinion.
Mean time, don't post anything that carries a copyright. We have to protect the owner of the board, who provides this venue free to those who enjoy his offering.
kenrinc
Re: Whistles
Post by kenrinc » Wed Dec 05, 2018 6:13 pm
That was a peculiar article with the author sighting 6 chime whistles as "out of tune messes". I was like, Huh? Anyway, I've built nearly 20 whistles, some of which work some of which don't :) I've bought pre-made whistles that worked on air and not steam. Horizontal whistles are a pain but it's traditionally the way WE integrate them since they look like an air tank. The key is keeping them hot. Some pipe the blower line through the center stem of the whistle others just nick the valve so it's always got a slight leak. I've done this and it works quite well. cbrew had a whistle mounted vertically through the running boards that I thought was a great idea. You could have the majority of the whistle in the cab with just the bottom sticking out. Although I agree the english whistles aren't my cup of tea, they are easier to find mounting places for since their generally shorter. I have experimented with single note hooters since they are so easy to make. I have a single note on my A3 that I tuned to a pretty good approximation of a PRR banshee hooter. Quiling isn't as pronounced (or even exists) on smaller diameter whistles.
Ken-
