I'm wondering about pipework for injectors. I have 2 locos with Superscale injectors, both piped with 5/16 lines in and out (I think... not near the locos this weekend while I ponder this question). Both setups work fabulously. My question is this: what is the relationship of the water supply and delivery lines, and then the check valve? For instance could you supply at 5/16, but deliver to the check valve at 3/16, or 5/32? Do injectors handle this?
Related to this, I see British type injectors rated with numbers (No 2, 3, 4, 5, 6)... but in 7 1/2" and 7 1/4" gauge equipment (all scales) there are no such designations, even with Superscales line of different injectors, and with Eccentric Engineerings new offers.
Thanks,
-Richard
Injector Questions
Re: Injector Questions
The number designation on the injectors sold in England is in reference to delivery capacity. Here's a link to a website page of English injectors: http://www.livesteammodels.co.uk/shop/i ... ath=49_149
The capacity is given in pints per minute for each size. They are sold in both horizontal and vertical versions of each size. I have a #4 injector on my 1" scale loco. My boiler barrel is 5" in diameter by 19" long. The injector feeds it well, and including shipping price, it is a bit more economical than the injectors sold in the U.S.
David
David
i'm don't know for sure but I would thing a 3/16" delivery line would be too small. I once worked on an engine with an LS Chicago injector that would not work; just blew water/steam out the overflow. It had a 5/16" delivery tube but it turned out to have only a 3/16" ID. heavy wall brass tube. I changed it to 5/16" copper tube and the injector started working.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Thanks for the comments. It would make sense that the injector and check valves be matched/compatible in terms of pathway diameters.
general guide: the feed / output lines from an injector can never be too big....
Also, too small of a water feed line will also mess up an injector. I had too small of a filter on my injectors and while they would put water in the boiler, probably 20% went on the ground. Granted mine are up in the lifting position, but switching to a larger filter corrected the problems and the injectors ran with a dry overflow afterwards
-Tristan
Projects
Projects
