Locomotive Steam Chest Question
Attached is a clip from H.J. Coventry's B & O 4-4-0 drawing prepared in 1957. The drawing depicts the steam chest, indicating one hole centred on one side that is to be counterbored. Can anyone tell me what the purpose of this hole is. I have checked with a couple of guys and no one has been able to tell me
- Attachments
- B & O Steam Chest.JPG (33.43 KiB) Viewed 5295 times
Re: Locomotive Steam Chest Question
That is to keep the steam chest attached to the cylinder when the cover is removed. Helps out when you are timing the locomotive.
Tim
Tim
That is to help in timing the engine, when you have the cover off, keeps the steam chest bolted in place
I would agree with Tim. This is for a screw to hold the chest to the cylinder while adjusting valve events. You can also leave the studs in the cylinder with spacers under the nuts to hold the chest to the cylinders while adjusting valve events. Depending on how tight your packing is on the valve spindle, you may actually want another of these counter bored holes on the other side to keep the chest straight. As the valve spindle moves through the packing, it will tend to pull on the chest and turn it sideways (unless you have the single screw in the counter bore really tight).
David
David
Seems like a bit of a bother; studs or running in a couple shorter screws would do as well or be better, it seems?
I have put two recessed bolts on the steam chest on all the locomotives I have built. It will save the lower gasket from being ruined or torn if the steam chest moves while adjusting the valves.
Ken
Ken
I just leave one bolt in the chest cover and swing the cover out of the way.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Good tip Ken!
i do it with a plastic cover held in place with the same studs that hold the metal chest cover in place. This way you can see to adjust AND RUN with 'eyes on the subject'...
