What Engine Is This
- SZuiderveen
Re: What Engine Is This
They also don’t drip down you neck while shooting rods. Also, no stress on the pressure vessel by having the bracket riveted directly to boiler. Also cleaner air to air filter.
longer trains= more air required for brakes, which means bigger pumps to keep the air pressure up. I just figured the pumps were getting large enough that they wouldn't fit in/around/under the running boards any more, and thus they moved them up front. Also, putting them on the smokebox front of an articulated would have simplified the piping, as it could be hard-piped since it wouldn't have to swivel with the front engine when going through curves.
Maybe if they were dropped down onto the pilot, the length increase was a problem?
- JBodenmann
Hello My Friends
Fender brings up good point. I think the reason for mounting them on the smoke box versus the pilot is that this is an articulated engine. The pilot wiggles all over the place. To run steam and air lines to the pumps from the boiler and to the pilot would involve a lot of flexible piping.
Jack
Jack
Seems like the Great Northern mounted air pumps at the front of many of its locomotives. Here is S2 number 2584 in Havre Montana.
Articulated locomotives with air pumps on the smokebox front did not require flexible steam and air line due to a moving front engine.
- dwilloughby
Off subject, but a nice Christmas Card from Leanin' Tree, by Howard Fogg?
Actually, that was Pontiacguy’s point, not mine. But I agree, the piping is much simpler on articulated locos, if the pumps are on the smokebox. I hadn’t thought of that.JBodenmann wrote: ↑Fri Feb 08, 2019 7:37 pm Hello My Friends
Jack
Dan Watson
Chattanooga, TN
Chattanooga, TN
It's entirely plausible that the air pumps were on the smokebox due to clearance issues... Tunnels, bridges, etc... Just a thought.
Is the engine not a C&O H7 simple simon.
