Pipe fittings
hoppercar
Pipe fittings
Post by hoppercar »
Has anyone found a good way to tighten close pipe nipples, without having to use pliers, and tear up the threads
cbrew
Re: Pipe fittings
Post by cbrew »
I have always tightened them during final assembly with the mated fitting
squirrel22
Re: Pipe fittings
Post by squirrel22 »
Hello, Tap the same thread in a bushing and split one side. Clamp in a 3 jaw to tighten and then loosen chuck to remove bushing.
Frank Ford
Re: Pipe fittings
Post by Frank Ford »
An "internal pipe wrench" with its knurled eccentric cam will tighten or loosen the closest of nipples.
I make a miniature analogous tool that fits into 1/4" phone jack to allow tightening the retaining nut from the outside of an electric guitar:
http://www.frets.com/HomeShopTech/Produ ... ipper.html
Cheers,
Frank Ford
