McMaster carr part number
BClemens
Re: McMaster carr part number
Post by BClemens » Tue Feb 26, 2019 5:48 am
copper_tube_reference_information.pdf
(13.61 KiB) Downloaded 67 times
BClemens
Post by BClemens » Tue Feb 26, 2019 6:47 am
1/4" copper tubing is 3/8" OD.... if you're going to use Ø 3/4" tubing for flue tubes, you had better bore a Ø 7/8" hole for it.
Copper Tubing.pdf
(252.04 KiB) Downloaded 59 times
Post by Bill Shields » Tue Feb 26, 2019 7:22 am
not disagreeing with you, just making an observation
https://www.homedepot.com/s/3%252F8%252 ... ing?NCNI-5
BClemens
Post by BClemens » Tue Feb 26, 2019 7:40 am
The designation or use is the key to the whole thing, not to say that a plumber cannot use refrigeration tubing or vice-versa but it is certainly sad to order a few hundred dollars worth of 3/8" tubing and find that it is 1/2" OD. The two rolls of copper on the left in the HD photo are 1/2"OD.
I never spent too much time doing plumbing, only when I was forced into it but sizing what you're working with is down right important. It's also important to refrain from changing hard fast and obvious rules.
BC
John_S
Post by John_S » Tue Feb 26, 2019 3:15 pm
My local Ace Hardware sells the coils of heavy wall tube. A long time ago I bought one coil each of 1/4 and 5/16 and still have a lot remaining after piping two locomotives.
