Miniature millwork plus
- Greg_Lewis
Here are a few snaps of the doors for the cab for old # 26 1/2.
One of the things we learn in this hobby is to plan the order of operations before you start making parts. If you don’t do that you can get into a corner that you can’t get out of. In this case I had to make the door stiles and the door frame uprights first so I could cut the rabbets for the hinge plates and get everything aligned. The hinges have to match up perfectly. There would be no way to do that after the frames and doors were assembled. I hate cutting wood in the mill and rarely do that but in this case I had to in order to get the depth of cut and alignment right.
I started with the hinges. I looked at dollhouse and jewelry box hinges but everything I found was too big. So I took a lesson from Jack and made these. I had some brass tube that was about 3/64 o.d. that worked perfectly when silver soldered onto some .010 brass shim stock.
Here’s a door frame rail with the rabbet for the glass and a tiny biscuit. I thought I could just butt join the door stiles and rails but after thinking about it I realized that a butt joint wouldn’t have the strength I needed. This isn’t going to be all that much stronger but it’s better than nothing, and it helps with alignment when gluing. The glass will be glued into the rabbets, which will add quite a bit of support to the assembly.
The glass is hard to see in the photo. Found some .050 thick glass in picture frames at the dollar store.
I made tilt-out windows in the doors operational as Baldwin had them. Here’s one with quadrant. The wood on the inside isn’t prototype but I wanted to hide the glue that holds the glass in. Clear, solvent-based cement such as Duco or similar will adhere glass to metal good enough for this application.
The complete window assembly with mount bracket. All parts were bead blasted and treated with brass black. They’ll be painted but this is insurance against bleed through or chipping. The little defects that show in this photo will disappear after painting and when viewed at more than 12 inches.
Test fitting in the door. The rabbets for the glass were painted black before assembly as the bare wood inside the rabbets would have shown through the glass. I forgot to treat the hinges with brass black. Too late now as the brass needs to be super clean for the brass black to work. I might try getting in there to clean with some acetone on a Q-tip.
- Greg_Lewis
Re: Miniature millwork plus
Part II:
I drew up the quadrant with my little shareware CAD program, printed it out and pasted it onto the brass. Cutting it out with a jeweler’s saw was easy.
Here’s the door in it’s frame with the tilt-out window installed.
And here’s a long shot of the finished door in the frame. The frame will become part of the front wall.
This has taken way too much time but, hey, as Jack says, too much fun.
Finally, this is the home-made saw I use for cutting little bits of stripwood. The motor is on the other side and is salvaged from a copy machine drive. I made this years ago when I was playing with HO trains. The fence is on lead screws front and back and I can cut to ±.003 if necessary. The blade is a 4-inch diameter blade that was made for a Dremel table saw. Unfortunately they're no longer available and any replacements I've found have a different arbor hole diameter, which would mean a reworking of the saw.
Harbor Fright sells a mini chop saw and a mini table saw that use a 4" or maybe a 3" highspeed steel blade. My wife has both of these units and loves them.
Can you make an adapter ring to fit a different blade?
Fred V
Pensacola, Fl.
Pensacola, Fl.
- Greg_Lewis
Thanks for the tips, Fred. I tried a Horrible Fright 4-inch blade, which is really only 3 3/4, but it's a 24 tooth and doesn't work well on tiny bits of wood. It's a good value, though. I note that they have some 5-inch 32-tooth blades I might look at. Porter Cable has a 4 1/2-inch 120-tooth blade that looks good but the arbor hole is 3/8, which would require a re-work of my saw. The saw arbor is 1/2 and runs all the way across between pillow blocks at each edge of the table. I might try a Porter Cable blade and see if I can open out the hole. There are also slitting saw blades but they don't have the tooth set that wood cutting blades have.
The Dremel blade was great but I made a "tactical error" and ran my otherwise flawless Starrett 4-inch double square into the blade. Now the blade is bad and my square has a ding in it. As my sig line says: Celebrating thirty years of turning perfectly good metal into bits of useless scrap.
Have you looked into what Micromark might have in terms of blades ?
They sell similar mini table saws like the Dremel, and Proxxon saws.
Super nice work on the hinges and frame.
- Greg_Lewis
Thanks for the suggestion, yes. They are all too small in diameter. A blade I ordered off Ebay arrived today that is 4 1/2 inches in diameter, 40-tooth with a 5/8 arbor hole. I'll make an adaptor bushing tomorrow and we'll see how it works.
And thanks for the compliments.
Micro Mark has a 4 inch 40 tooth carbide tooth blade with a 1/2 inch arbor hole. item number 60294
They have a super fine tooth 310 tooth hollow ground narrow kerf 4 inch blade with 1/2 inch arbor.
Herman
Herman
Just starting an Allen Mogul
renewing a Marie Estelle
Greg,
very detailed miniature work, looks fine!
Asteamhead
Asteamhead
- Greg_Lewis
Thanks, Herman. Somehow I missed those. The blade I mentioned above has been mounted and works well with a slow feed, so now I'm back in business.
Thanks, Asteamhead, for the compliments. This has been a fun project. I love working on little fiddly stuff.
This is one of the best saws on the market.
http://www.byrnesmodelmachines.com/tablesaw.html
Thickness sanders.
http://www.byrnesmodelmachines.com/sander5.html
Thickness sanders.
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
Current Projects:
