Is it better to have all of the steam/water supply lines the same size or different? Looking at old LE plans, they say 3/16 steam valve to 5/32" tubing to the injector. Water is 3/16 in, combined out is 5/32, reduced to 3/16 to boiler valve. Looking at several injectors online (Reeves, EE, and others), same oboe size on all.
Trying to do it right the 1st time....
Injector piping question
Christopher P. Mahony
Los Angeles Live Steamers
1 inch scale member
1 inch scale member
Re: Injector piping question
I've always made my lines the same size: Steam, water, and outlet, and my injectors have worked really good, with the exception of one English injector that turned out to be a low-pressure injector. It's hard to get an injector that was made for 100 PSI max operating pressure to pick up at 120 PSI! All the injectors that I have installed or ever fooled with have had the same size fittings on each location.
Thank you. I will plan for 3/16 piping
1 inch scale member
1 inch scale member
Never hurts to go one size larger. What type/size injector are you going to be using?
Was looking at EE 1” scale injector. It has options of 3/16” or 1/4” on all connections.
1 inch scale member
1 inch scale member
When I replaced my English injector for A small EE injector I used the existing 3/16 steam and 1/4 inlet and out water lines and it works great from 40 to 105 psi no more stopping to fiddle with the injector when the axle pump gets behind .
www.chaski.com
