Another Injector Piping Question
bill4227
Post by bill4227 » Fri Mar 15, 2019 12:34 pm
Can an injector share the same boiler water input with a hand pump?
AnthonyDuarte
Re: Another Injector Piping Question
Post by AnthonyDuarte » Fri Mar 15, 2019 1:03 pm
The delivery line can be shared with other water inputs, but it must have its own check valve to prevent the output of other feeds interfering with the injector's operation. You also don't want the injector feeding back into other sources. It's best practice to have an injector's inputs and outputs be entirely isolated if possible. It is a requirement (not a recommendation) that injectors have their own dedicated water line from the tender.
cp4449
Post by cp4449 » Fri Mar 15, 2019 5:55 pm
Also make sure you have a filter on the injector line
Christopher P. Mahony
Los Angeles Live Steamers
1 inch scale member
