Pipe thread sealant?
ccvstmr
Re: Pipe thread sealant?
Post by ccvstmr » Tue Apr 02, 2019 4:22 pm
Our resident boiler fabricator has suggested using anti-seize compound on flange gaskets. Easier to take things off (like a steam dome) without damage to the gasket. My fall-back for years for the same application was graphited steam oil. But sometimes still had separation anxieties!
Threaded joints...recommendations have been made to use Loctite 567. After doing some boiler plumbing re-work, filling the boiler with air and performing a bubble check...
NOT GOOD! I know the tube of material was "old", but couldn't find any info regarding shelf life. Problem could have been didn't pack enough Loctite into the threads...or the stuff was old...or other. Sure had enough of the white stuff on my hands (and everything else)...
Alternate...friend came up with some Permabond LH050 at the suggestion of some contract pipe fitters. Their company wouldn't buy this stuff for their workers anymore because of the cost. But they said the stuff DOES work! Similar to other thread sealers, this too is an anaerobic material. So the threaded joints were taken apart, cleaned and reassembled with the LH050 and...
Maybe it costs a lot because it works. And no, the photo sequence was not reversed or the photos edited.
Hope to test the plumbing (and the rest of the boiler) sometime during April. Stay tuned. Carl B.
Post by Bill Shields » Tue Apr 02, 2019 5:12 pm
giggle...PTFE has no shelf-life....
ccvstmr
Post by ccvstmr » Tue Apr 02, 2019 8:19 pm
Bill...PTFE might have no shelf life, but it's suspended in some kind of media that might. Don't know if kneading the tube to mix the paste up before use would help or make a difference. As a side note...have a small bottle of Teflon grease on the shop table. Whatever is mixed in with Teflon DID separate. Looks like an oil on top and the rest of the lubricant underneath...a Teflon parfait! Just sayin'... Carl B.
Post by Bill Shields » Tue Apr 02, 2019 8:37 pm
I was referring to pure PTFE tape...never goes bad and can always be pulled out of the toolbox and used.
I have no idea about the other stuff...have not used it...lots of good comments from others.
rkcarguy
Post by rkcarguy » Wed Apr 03, 2019 1:05 am
When we installed the laser plate table at work there was a "gap" in coverage of the install. We were supposed to supply the o2 and Nitrogen lines going from the wall to the machine and thought the laser table company was. They needed to be good to 500 PSI, so I purchased, flushed, cleaned, and assembled the lines and fittings and used what was supposed to be this liquid PTFE stuff that was supposedly used on the space shuttle blah blah blah. It was junk, almost every connection leaked. I had to tear it all apart, clean it all off and flush all the lines again, and then I re-assembled it with the yellow natural gas and oxygen service rated Teflon tape and had no leaks. I have also had good luck with the Loctite thread sealer but prefer the tape. It's easy to clean off and if there is a leak sometimes the fitting can be tightened a little bit more where a dried product would be "broken" and require taking the fitting apart again. Also, no waiting for anything to dry or cure, tape is ready to go.
Post by NP317 » Wed Apr 03, 2019 10:15 am
I used that yellow gas-rated Teflon tape on the propane connections on my locomotive burner systems.
Works perfectly.
Sftyvlv
Post by Sftyvlv » Sat Apr 13, 2019 4:01 pm
Masters Pro Dope and Metallic Compound are the only sealant our steamfitters use.
Cary Stewart
Post by Cary Stewart » Sat Apr 13, 2019 5:21 pm
Hi Dianne,
This is not about this thread but should be of some interest to you.
Go to Facebook, Live Steam History of Sothern California, Mike Massey photo just loaded.
The photo is a 1957 shot of a Little Engines 4-2-4T C.P.Huntington. It is the prototype of your 4-4-0. All that was done was remove the tank and 2 axle truck and add a second drive wheel set. Possibly also lengthened the boiler a little. L.E. sold these for a few years but not for some decades. I don't know if the current owners of L.E. materials still offer the American.
Cary
Fred_V
Post by Fred_V » Sun Apr 14, 2019 7:24 am
I've been using a pipe thread dope from Home Depot that is steam rated.
Fred V
Pensacola, Fl.
