Driver Casting Repro
jlakes85
Post by jlakes85 » Sat May 11, 2019 2:16 pm
Hi All,
My first attempt at a pattern and repro. Next step is to pour the 8002 again and get the plastic pattern. Thoughts/comments?
-jlakes85
Greg_Lewis
Re: Drivre Casting Repro
Post by Greg_Lewis » Sat May 11, 2019 6:47 pm
My thoughts and comments are: Congrats. Folks who haven't done that don't know how much work goes into it.
Builder01
Post by Builder01 » Sat May 11, 2019 8:39 pm
Looks nice. Will this be in iron?
David
jlakes85
Re: Driver Casting Repro
Post by jlakes85 » Sun May 12, 2019 7:03 am
Thanks Dave, yes this will be gray iron.
Greg, I had to use 2 kwik cast gallon kits to get enough material..I made the pouring window probably by seconds..even with a few dry runs and a clean floor😁
jlakes85
Post by jlakes85 » Sun May 12, 2019 7:04 am
There were some spots where it grabbed for one reason or another. Can anyone recommend a method to check over the negative before I pour the positive to avoid future issues?
Fred_V
Post by Fred_V » Sun May 12, 2019 7:17 am
Do you have enough draft on the pattern to let it release?
Fred V
Pensacola, Fl.
jlakes85
Post by jlakes85 » Sun May 12, 2019 7:33 am
Hi fred,
Yes, I should be good on the major surfaces and I did use beeswax in the questionable corners. I think I screwed up by not getting the actual BCC release agent. I thought I could skate by using a furniture polish, as did McCord on YT when he poured that Wright brothers engine, but they was to release the pattern from the sand, not repro plastic..lesson learned l and I still have a master pattern to tell the tale..😁
Fender
Post by Fender » Sun May 12, 2019 7:46 am
I assume the pattern was a 3D-printed model. These often have ridges or lines on the surface, which must be filled with paint or sanded off to get a clean pull from the mold. Is this a problem with yours?
Dan Watson
jlakes85
Post by jlakes85 » Sun May 12, 2019 9:21 am
Hi Dan,
This pattern is made from poplar, piece by piece. Some of the joints were challenging to fit and might have some issue areas. I'm going to order the proper BCC release agent before pouring the repro
Trainman4602
Post by Trainman4602 » Mon May 13, 2019 3:11 pm
Hi have made several videos about this process on you tube watch them
Post by Harold_V » Mon May 13, 2019 3:43 pm
Have you considered ductile instead? Far more reliable.
Builder01
Post by Builder01 » Mon May 13, 2019 4:55 pm
Reliable? How does gray iron fail?
David
