Driver Casting Repro
KarlKobel
Re: Driver Casting Repro
Post by KarlKobel »
Rub the pattern with graphite.
That made a big difference even with 3D printed patterns.
Karl
Builder01 wrote: Mon May 13, 2019 4:55 pm
Harold_V wrote: Mon May 13, 2019 3:43 pm
jlakes85 wrote: Sun May 12, 2019 7:03 am yes this will be gray iron.
Have you considered ductile instead? Far more reliable.
Reliable? How does gray iron fail?
David
Gray iron is prone to cracking, very unlike ductile. It is also much lower in tensile strength, depending on the alloys in question. All properties being equal, ductile is stronger. That's due to the fact that the free carbon (graphite) in ductile being tiny spheres instead of flakes. The result of using ductile is that it can be readily welded, it has greater tensile strength and is ****ductile****, very unlike gray iron.
Interestingly, chemically they're almost identical. Gray iron is inoculated in order for ductile to be poured. The one caveat is that the sulfur content must be low, otherwise it interferes with the inoculation process. With modern melting techniques (induction melting instead of cupola melting), it shouldn't be much of an issue to the foundry.
Where ductile really shines is that flanges are not easily broken. Ductile wheels have the potential to withstand a lot more punishment in a derailment. All in all, a better choice. They machine almost identically, although ductile yields chips that tend to hold together, but are readily broken, while gray iron tends to yield crumbles. Both are "dusty" (therefore dirty) to machine.
jlakes85
Post by jlakes85 »
Dave,
I watched your video on the driver pattern a few times before I started prepping everything..and then a few times more when I was mixing the stuff. Top notch as always.
-jlakes85
Pipescs
Post by Pipescs »
Are you using Kwick Kast parting wax?
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
jlakes85
Post by jlakes85 »
Charlie,
I just had my first quart delivered today..no more screwing with furniture polish..I learned my lesson😁
optigman
Post by optigman »
Challenge 95 release from BJB Enterprises in Tustin, Ca works as it's supposed to in a Patternshop environment. Must dry completely before any plastic is poured against it. Lacquer sanding sealer is far better than paint as a sealer for the wood or plastic pattern. Proper draft and smoothness of pattern is critical.
RONALD
Post by RONALD »
I did some drivers by a different method, I made three Match Plates.
I then used CO2 sand to make the mold, and being hardened it was easy to bring the molds to that iron foundry mentioned below:
http://www.chaski.org/homemachinist/vie ... 7&start=12
jlakes85
Post by jlakes85 »
Hi All,
Here is the end result. Not too bad I don't think. I'm letting this park on the band saw table overnight to set. Thanks for all of the pointers and suggestions. Next up are the cylinders.
-jlakes85
Trainman4602
Post by Trainman4602 »
What is all the roughness from. It should be smooth as a babys butt
Trainman4602
This is picture of a mold for the 0-4-0 driver and also the match plate
John Hasler
Post by John Hasler »
This is interesting:
http://www.ijirse.com/wp-content/upload ... /1160B.pdf
They are 3D printing the moulds directly with sodium silicate/sand using a process similar to the laser sintering process but with a CO2 jet instead of a laser. No pattern at all.
jlakes85
Post by jlakes85 »
Hi Dave,
The white stuff is plasticine that was used in a couple of questionable areas. I still have to remove that and give the pattern a once over before mounting
