Piston Ring Port Sizing
JKreider
Post by JKreider »
Has anyone come across any standard for the maximum port size (along the circumference of the ring) that cast iron piston rings can slide over without danger of scuffing the ring and/or port, based on ring OD and thickness?
Jim Kreider
Reason: correct subject so searches will be successful
Rick
Re: Piston Ring Post Sizing
Post by Rick »
Jim
In two stroke engines the racers will go with exhaust port widths up to 60-70% of the bore.
I have a copy of Lima's standards, don't know if there is anything in it about this but I will look tonight.
Rick
“We make a living by what we get, but we make a life by what we give." Sir Winston Leonard Spencer Churchill (1874-1965)
"Peace is that brief glorious moment in history when everybody stands around reloading". Unknown
Murphy's Law: " If it can go wrong it will"
O-Tool's Corollary: "Murphy was entirely too optimistic"
Rick
Post by Rick »
Jim
Lima's standards do not have any info on port design.
Rick
Asteamhead
Re: Piston Ring Port Sizing
Post by Asteamhead »
Hello Jim,
Using 2 or 3 rows of drilled ports instead of milled rectangular ports works fine, too. There are no restrictions as long the diameter of the drills is below the width of the piston rings. Total cross section thus maybe up to 40 % of diameter x width x pi (liner port).
Just my two cents.
Asteamhead
A valve liner made of bronze with drilled ports
