tire shrinkage
hoppercar
tire shrinkage
Post by hoppercar » Fri Oct 25, 2019 12:49 pm
what is a good rule of thumb for shrinking steel tires on cast iron centers?....I've heard .001" fo r every inch in diameter.
rkcarguy
Re: tire shrinkage
Post by rkcarguy » Fri Oct 25, 2019 12:52 pm
That's correct, another thread discussed this maybe 3 weeks ago?
So 10" drivers, make the tire bore .010" smaller than the center.
cbrew
Re: tire shrinkage
Post by cbrew » Fri Oct 25, 2019 1:08 pm
I personally use .001 per inch of diameter plus .001
FLtenwheeler
Re: tire shrinkage
Post by FLtenwheeler » Fri Oct 25, 2019 2:15 pm
I also use 0.001” per inch plus 0.001”.
I just did some 8” drivers and it was right on.
On a side note the axle bore shrunk 0.0002” after I installed the tires. I had to take that much off the arbor I was using to turn the wheels.
Tim
hoppercar
Re: tire shrinkage
Post by hoppercar » Fri Oct 25, 2019 3:46 pm
I'm not planning on pressing mine off of the axles, just turn them down between centers, and shrink the tires on.....so the axle bore won't be a problem
