This is a RR Supply heavy mike. The assembly drawing shows the wrist pin pinned to the crosshead. Main Rod rotates on the wrist pin. So I am overthinking bushing material.
Not too keen on silver soldering this big piece. Not enough practice. Guess I should make the bushing a couple thousandths undersize on the OD. Then center punch 120 degrees around the circumference on both inboard and outboard. Clean, slather up with flux and go to town with heat on the crosshead.
I like Dick's idea of "reamed about half the depth of the hole to be a close fit on the piston rod and threaded the second half". However, how do you lock the piston rod after adjustment? Pin it? Or do your adjustment on the piston end and cut off any excess piston rod in the cylinder?
Dale Grice
Crosshead machining woes
Re: Crosshead machining woes
Projects:
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
RR Supply 90 ton Logging Mikado
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
I'm guessing here that the wrist pin rotates in a bushing in the connecting rod. If so, then the material in the cross head is of no great importance.Dale Grice wrote: ↑Wed Jun 15, 2022 2:37 pm I did not think of the jam nut. Good thought.
But, the real question at this point, what would you use for a bushing in the wrist pin hole?
I need to bore it out and bush it. How big? maybe an 1/8 diameter oversize. What material should I use to bush it? Brass, Silicon bronze, 1144, 1018? Wrist pin is drill rod.
Dale
Just be sure that the oversized bore in the cross head is in the correct location, in which case a concentric bushing will serve. Methinks a 1/16" bushing wall thickness is sufficient.
Since the cross head is bronze you may wish to make the bushing of a matching bronze, also. I would soft solder this bushing into the cross head. Excess solder may be filed off. The bushing outside diameter should have .002" to .003" diametral clearance for this soldering.
Best pin bushing material is either delrin af or nylatron
Both will take an unlubricated pounding and not wear
- Dick_Morris
I'm going to silver solder a shoulder onto the rod, mostly for appearance. Then use a taper pin in the location that the tapered key is on the prototype. I'm hoping that I don't have any need for adjustment, but if I do, it can be done with a shim or removing material from a shoulder at the piston end. I will be using the same combination of reamed hole and some threads on the piston end. The piston end of the rod will have a shoulder, but will also have a recessed jamb nut.I like Dick's idea of "reamed about half the depth of the hole to be a close fit on the piston rod and threaded the second half". However, how do you lock the piston rod after adjustment? Pin it? Or do your adjustment on the piston end and cut off any excess piston rod in the cylinder?
I'll probably try and put a couple of flats on the visible end of the taper pin so it looks more like the prototype's flat tapered key. I've cut high speed steel with carbide tooling, we'll see how hard taper pins are. If necessary, I can even anneal the taper pin as the hardness isn't important for this application.
Taper pins are generally not heat treated.
- Dick_Morris
Harold - Thanks. That's good to know.
There ARE the occasional times when they need to be drilled...
