Al, remember that if you put a long rod on those oscillators by putting the cylinder up front and connecting to the center driver, you may not have enough "wobble" to make the engine work properly. [img]/ubb/images/graemlins/frown.gif"%20alt="[/img] All of the original oscillator locomotives I have seen (in pictures) connect the cylinders to the front driver for maximum wobble. [img]/ubb/images/graemlins/cool.gif"%20alt="[/img]
Unka(who has built several oscillators including the Newbie Project engine) Jesse
Effects of vertical movement on valve timing
Re: I would think you should hang the engine ...
- willjordan
Re: Effects of vertical movement on valve timing
I know of two members of the Kitsap Live Steamers that built WATO Lil Limas. One used the original Hackworth gear, the other went for Walsharts. The owner of the Hackworth geared engines said that loading made a definete difference in the valve timing.
grace & peace
will
[url=http://willjordan.com]Will's Web Pages[/url]
will
i wonder what this would do to the Hackworth2 or Marshal gear. it uses swinging links rather that the sliding block but it is still mounted directly above the driver. i'm looking at using Marshal gear on my new engine.
fred v
fred v
Fred V
Pensacola, Fl.
Pensacola, Fl.
Hi Fred
It will have the same effect as Hackworth
This will be another area I would limit the travel of this axle
Chris
Chris
Thanks for all the good advice, but one question remains un-answered: Just how much in fractions of inches do our little engines' wheels bounce up and down while in operation?
Al Messer
"One nation, under God"
