Complete Newbie Project
NEWBIE PROJECT IS FINISHED!!!!!! Yay!! At least I hope it is finished. I stayed home from the local Heritage days thingie to make the stack and top, replace a few bolts where I had used round head screws. Things like that. I am sure there will be problems at the track with leaks in the steam and water lines, but I always carry a complete set of tools with me and in this case I am carrying a few spare chain links. I believe that I will have to shorten the two long chains by a half link after it has been run a bit and everything settles in.
Reverse lever is the crank thingie and the throttle is the wooden handwheel a couple of inches above it. I put on an L&N RR type brass flare on the stack. Next week (barring constant rain) should tell if the thing will fly of if the engine is too small as is. Engine bore can be easily increased should power be inadequate.
SEE ATTACHMENT!
Unka(Gonna sit back and un-lax for a while)Jesse
SEE ATTACHMENT!
- Dick_Morris
Re: Complete Newbie Project
Way to go Unka!
You've already had a break of an hour or so, have you started something new yet?
Hey unka jesse,
Sure looks good,
let us know how she runs
Chris
Sure looks good,
Chris
... Very nice my friend. Looks great!
BG
BG
- Location: Alsace a Part of France along the Rhine River
Huiiii. Not bad. Not bad. I wait for what this thing pulls away.
Have Fun
dampfwilli
You must not be crazy to play with steam, but it helps.
dampfwilli
Newbie was steamed for the first time today. It took about 12 minutes to get the gauge hand "off the peg" and as pressure came up, a few leaks showed up which was to be expected. Engine could be operated back and forth only for a total of six inches on the stand, but it appeared to be pretty lively. A good bit of leakage at the oscillating cylinder seats, but this should improve with running. Steam pretty well stayed up at 80 PSI with one safety lifted, so I should have enough steam. [img]/ubb/images/graemlins/cool.gif"%20alt="[/img]
Weather supposed to be dry next two days as the rain clouds store up water for the Mid-South meet so I should be able to load the engine onto the mighty Dodge tomorrow afternoon. [img]/ubb/images/graemlins/smile.gif"%20alt="[/img]
Unka(happy so far, but this may change next week)Jesse
Jesse, I sure do hope that it runs as well as it looks. Congratulations on a project well done.
Al Messer
"One nation, under God"
Hey Jesse;
What about putting some lapping compound in between the cylinders at initial building to facilitate the "seating" of the cylinders? Or do you think it would make it leak too much? I suppose the builder could do this and run it on air before the loco is done? How about your thoughts?
-willy-
-willy-
Willy, I did use some fine valve grinding compound to lap in the cylinders, but I 'spect actually running the engine will seat everything in place, (I hope, I hope, I hope)!! Newbie Project is now loaded in the mighty Dodge Cummins and awaits connection to the fifth wheel trailer for the trip to Columbia. Auntie Fern and I worked on getting the trailer shipshape this afternoon. As I have stated before, there is the possibility that I need larger cylinder bores for more power. The boiler really makes steam so there is no problem there, but we shall see if the engine is adequate come Wednesday morn when everything gets seated in. [img]/ubb/images/graemlins/cool.gif"%20alt="[/img]
Unka(ever hopeful)Jesse
Congratulations on completing your engine. Looks outstanding!
